B18C1 HELP
B18C1 HELP
Hello I just traded my Del Sol with a B16A1 to a friend with a 00' Civic with B18C1
I like the car alot better..but none of that is really my question
Basically Im looking to build my car NA or Turbo
I heard that you cant turbo a B18C1 High Compression or something ( im new to this)
But i can trade the GSR head for a LS head and then turbo it.. and be good
What are some building blocks I should look at
and some good companies.. spending around 3-5k for a daily driver, but quick Red light to Red light...
oh yah side note.. I plan on getting it tuned from Neptune and Having them put a EMS in
Re: B18C1 HELP (Truaries)
if you want turbo in a b18c1 you can but the most i would boost is 7 psi un less u get aftermarket injectors , fuel pump ,fuel rail and fuel regulater
DO NOT trade the gsr head for a ls head.....keep the gsr...boost and tune...my brother boosted his gsr at 8 and it was fine...if you want more boost...sell the gsr...get a ls...i think ls will handle up to 12 psi of boost stock block and internals...
Re: (808_si)
actually the gsr vavletrain is good for boost. ive seen a b18c1 boosted at 10psi making 300 whp.. high compression doesnt mean you cant boost, it just means the tune has to be that much better..
Re: (cambopheonix56)
So from what im getting is the GSR is okay to boost just have to have it tuned...Neptuner is doing the tune.. with there whole ems system
Turbo is down the road
I want to build the internals up first. What should I do to prepare for the turbo
Re: (Truaries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Truaries »</TD></TR><TR><TD CLASS="quote">So from what im getting is the GSR is okay to boost just have to have it tuned...Neptuner is doing the tune.. with there whole ems system
I want to build the internals up first. What should I do to prepare for the turbo</TD></TR></TABLE>
well if your going to do this, lower the compression to 9.1:1 by getting some pistons, get some eagle rods and then you can boost it a lot higher then 10 psi or so. And like every turbo, tuning is key
Re: (Truaries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Truaries »</TD></TR><TR><TD CLASS="quote">being new to this all , where would I look and what is a good company?</TD></TR></TABLE>
Well as far as the kit goes, get a greddy turbo kit with an intercooler, you can find them brand new of ebay for like 2 grand or someting..
As for the rods, eagle makes them, and pistions, wiesco(sp?) makes good pistons. Just do a search and you can find there sites easy.
Re: (Truaries)
start researching. Do it right the first time. There is tons of information here! have fun!
If your looking for a real good turbo kit that only cost a little more than one of those crappy ebay ones go with a Peakboost kit, I havent gotten one( I dont own a civic anymore) but they use qualitly parts.
https://honda-tech.com/zerothread?id=1283105
Re: B18C1 HELP (fasthatchb18c1)
are you planning on doing ths yourself or having a shop do it?
if you have a shop do it, just drop them off about $2314123428970987145(probably around $5000) and have them build the whole thing for you.
labor is a bitch...
make honda friends.
labor is a bitch...
make honda friends.
How much power/boost can a b18c1 hold with out sleeves or deck plate etc? A couple of turbo question
80 dolla crx hf
10-24-2008 04:02 AM
SpeedDemonAaron
18
07-08-2004 12:49 PM
