B18C1 GSR JDM into my EJ6 hatch
Ok...first off, is there anything special header wise that I need to know about for a 1996+ OBDII GSR swap to be made to fit my 1997 Civic hatchbacks Magnaflow catback with cat delete pipe installed?
Secondly...anything wiring wise different...already converted my CX harness to accept the current SOHC VTEC d16Y8 swap thats installed right now...what else do I need to do aside from that and the engine mounts?
99-00 SI rear L bracket
99-00 SI driver side motor mount bracket
use ur civic harness and modify it to fit the gsr
if u are using the JDM ecu u dont have to worry bout emissions stuff, but if u use a USDM u will have to hook up secondary o2 sensor, CKF sensor, evap purge solenoid n something else i think. not sure bout ur magnaflow catback might be too short
most hood white kid
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">99-00 SI rear L bracket
if u are using the JDM ecu u dont have to worry bout emissions stuff, but if u use a USDM u will have to hook up secondary o2 sensor, CKF sensor, evap purge solenoid n something else i think. not sure bout ur magnaflow catback might be too short</TD></TR></TABLE>
as well as the IAB secondary butterflies...
Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">
as well as the IAB secondary butterflies...</TD></TR></TABLE>
Suprised to see this came so early in the post.
There is write ups about it or you could just remove them.
Only had to run two extra wires if your using the JDM ECU. Knock sensor and IAB like stated above.
Header will not be al problem. If your looking into buying one get one for the engine, not your car. i.e. buy a header for an integra gsr not a civic.
most hood white kid
Re: (B20 EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 »</TD></TR><TR><TD CLASS="quote">
There is write ups about it or you could just remove them.</TD></TR></TABLE>
yeah, alot of h22 guys I know dont even hook them up, or just remove them...
I hooked mine up b/c there was no wiring, already wired into my harness.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Since when was a B18C1 Jdm?</TD></TR></TABLE>
prolly just doesnt know that JDM engines dont have numbers in the engine code.
most hood white kid
Re: (Reedy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reedy »</TD></TR><TR><TD CLASS="quote">Only had to run two extra wires if your using the JDM ECU. Knock sensor and IAB like stated above.
Header will not be al problem. If your looking into buying one get one for the engine, not your car. i.e. buy a header for an integra gsr not a civic.</TD></TR></TABLE>
ahh..the honda knock sensor is trash IMO. by the time it catches something, the damage has been done.
Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">ahh..the honda knock sensor is trash IMO. by the time it catches something, the damage has been done.</TD></TR></TABLE>
yup. knock sensor was the only wire i had to connect. later just cut it out and got a chipped p28
Re: B18C1 GSR JDM into my EJ6 hatch (Hatch_Back_97)
i have a magnaflow from a eg on my ek hatch , and i just did this swap... i put a RSR gsr header on my jdm gsr and i had to extend the cat pipe about 6 inches and weld a o2 bung in it....since the RSR didn't have one
Ok, whats this about the IAB fix? Is there an article about this that you guys could link me to? Also, what about the shift linkage...can I hook it right up to my stock Civic hydraulic rods?
Re: (Hatch_Back_97)
Hydraulic rods?? Use the shift linkage from any b-series car except for the del so doch vtec. (it is too short.) Read in the FAQ at the top of the main page. Your IAB wire answer is there.
most hood white kid
Re: (e gee two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two »</TD></TR><TR><TD CLASS="quote">
yup. knock sensor was the only wire i had to connect. later just cut it out and got a chipped p28 </TD></TR></TABLE>
thats what I am running on my h22
most hood white kid
Re: (Hatch_Back_97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 »</TD></TR><TR><TD CLASS="quote">Ok, whats this about the IAB fix? Is there an article about this that you guys could link me to? Also, what about the shift linkage...can I hook it right up to my stock Civic hydraulic rods?</TD></TR></TABLE>
the IAB is a vaccum(at least it is on the h22) driven secondary butterflies. if you open up the plenum on the gsr IM(4 bolts I believe) you will se 8 little plates, 2 per cylinder. 4 of them(1 per cylinder) stay open constanly, the other 4 stay closed until you reach a certain RPM(3k or 4k rpm) the vacumm then opens the other 4 plates, I think its more for gas mileage than anything. there is rally no power to be gained by not hooking them up or removing them. if you dont hook up the IAB solenoid plug, all 8 will stay open contantly, and you will throw a CEL, you can remove them by opening the plenum up, and just simply taking the plates out. but you have to fill the holes where the bolts went with something, but its ALOT easier to wire up the IAB solenoid plug.
Re: (egcoupe94)
I understand what you're bitching about but he was trying to make it clear. Now, if he mention B18C we wouldn't know what the fukk he was talking about. Either B18c for type R or GSR. You see?
most hood white kid
Re: (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A »</TD></TR><TR><TD CLASS="quote">
I understand what you're bitching about but he was trying to make it clear. Now, if he mention B18C we wouldn't know what the fukk he was talking about. Either B18c for type R or GSR. You see?</TD></TR></TABLE>
he said b18c1 JDM gsr...when he said gsr, we knew what he was talking about.
Re: (egcoupe94)
lol...quit bitching...I need this done not a flame war over whos got more brains., lol. I know B18C GSR is in Japan and B18C1 is here, I'm so used to B18C1 I used that to diffirentiate between Type R versus just GSR to amke sure no one got it confused. So...I do indeed need shift linakge...great, my shipper forgot to include that like he had promised before. Well, how do I hook up the IAB...you say its on the FAQ somewhere...what page?
Re: B18C1 GSR JDM into my EJ6 hatch (egcoupe94)
there is your wiring guide.</TD></TR></TABLE>
There is not your wiring guide. OBD2 engine OBD2 car
Re: (Hatch_Back_97)
if you swap out the stock gsr intake mani like i did you don't have to worry about this, like a skunk2 or blox
Re: (ReDHaTcHyGuy)
Blox a good intake mani? Also, even if you swap out stock mani...won't it still look for the butterflys in the ECU?
Re: (Hatch_Back_97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 »</TD></TR><TR><TD CLASS="quote">Blox a good intake mani? Also, even if you swap out stock mani...won't it still look for the butterflys in the ECU?</TD></TR></TABLE>
yes and yes
yes and yes
Re: (Reedy)
actually it would be three wires - IAB is two, and Knock is one.
