b18b1 swaping into 97 civic coupe need wireing lay out????
ok me and my buddy just got a 97 acura integra b18b1 5 speed, abs, ac. but were not going to use the ac or abs i just need to know wat the wire set up for me to put it into a 97 civic ex coupe? any one help?????
Re: b18b1 swaping into 97 civic coupe need wireing lay out????
so there no one that can help me on this i know the injector and dizzy need some type of wireing work and if so wat wire need to be cut and pasted in
haha deff please anyone who knows anything about connecting the wire harnesses between a 97 civic ex d16y8 vtec and an integra b18b1... theres gotta be someone who's done a b18 swap into a 96-99 civic
injectors should be fine. both cars are obd2a so injector plugs should be plug n play. also if you're using the stock ex harness everything should be plug n play. the only thing i can think of is the vtec plug. just zip tie it to something since the b18b is non vtec. you mite have to extend some wiring but thats ez. hopefully you got the whole complete swap like dizzy, im, throttle cable, etc...gl.
i just got done swapping a b18b in my 2000 civic. had to extend alot of plugs because my car is obd2b. and then rite when i got it running right some idiot rear ended me. pissed me off hella bad.
