B18B1 swap into 95 civic, need help
Okay guys, im buying a b18b1 pretty soon and I need some info about what ill need.
Here's what comes with the motor:
Engine and gsr tranny
Shift linkage without shifter
ecu and engine harness
All engine mounts and brackets
half shaft but no axles
I have a 95 civic, so what else would i need to swap?
Any info is appreciated.
Re: B18B1 swap into 95 civic, need help
assuming the engine is obd1, all you will need is the shifter and axels. if you have ac you will need ac bracket.
x2 i don't think you need the 1.8 harness though.Pretty sure i used my factory one.Use your shifter.Also watch wat axles your buying you dont wanna end up with 90-93's and have to swap out your sideaxle seals.Been there done it lol.
WhtHatchBack
03-09-2005 08:01 PM
