B18b1 high idle help!!
Ok I have a b18b1 that was idling at 3200 so I tightened the FITV and it dropped to 1500 so I cleaned the iacv didn't do a thing. Checked for vacuum leaks couldn't find any. The only code it's throwing is the o2 sensor #41. Also there is no air in the cooling system. Any ideas?
Re: B18b1 high idle help!!
Adjust your idle screw correctly.. ill be nice, here you go
http://i267.photobucket.com/albums/i...cture_3365.jpg
You have a vaccum leak somewhere man. Check the nipple in the back of the intake-mani-fold, plug that. Ensure you don't have a leak on the PCV hose. Check your IAT sensor for leaks. Check your IAC mini gasket for leaks. Adjust your idle the proper way by unplugging your IAC, turning on your car. Setting it to roughly 450- 500rpms. Then plug your IAC, reset your battery, and start the car, it should chill near the proper RPM.
I believe I found my problem. Sprayed the tb again with brake clean and it stalled out. And I could feel the air it was sucking. I'm gonna change that and adjust the idle speed correctly and I'll update hopefully tmrw cause oem gasket is on order
I have same problem but can`t find why it looks like everything is correct and no vacuum leaks but it still idles 1000 1500 rpm-s
