b18b with tpye r trany into a 95 civic cx
HELP !!b18b with tpye r trany into a 95 civic cx?
i had this engine in my 91 teg tell i wrecked it so it has disrobuter from 91 on it, is there a wire diagram or wire harness i could use to keep from having to buy a new one because it is brand new. And also will i be able to get away with just putting a chip in ecu or do i need ecu out of a 95 integra (it is a non v-tec motor) also does any one know if my ac compressor off my d15b7 will mount to b18b, does anyone know if my type r trany is better then just regular b18 hydro?also what about shift linkage on civc will it mount up or is there one that will work?
Modified by kurtlmcculloch at 8:08 AM 8/21/2007
Re: b18b with tpye r trany into a 95 civic cx??????????????????????? (kurtlmcculloch)
Im not certain if you could chip your current D series non-vtec ECU, but I know you can just use the LS (P75) ECU.
As far as the A/C compressor, you will need the compressor from the B18b1.
A type R trans will be better than the LS trans and I believe you will need the LS shift linkage.
Re: b18b with tpye r trany into a 95 civic cx??????????????????????? (95ProjectEJ1)
what about the distributer, i need a wire diagram or wire harnes to convert it- do you know about that?
kurtlmcculloch
09-24-2007 04:03 AM
kurtlmcculloch
08-23-2007 09:09 AM
