b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust???
Will the stock b18b header bolt up to my stock DX exhaust? I now have all the parts to do my swap except for an aftermarket exhaust. Please let me know asap, swap begins in the morning... thanks...
drew
drew
Re: b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust??? (Tur*bLu)
not sure about EG hatch, but im pretty sure it wont
my EK, it DIDNT bolt up, it falls short
Same with EG I assume....
Re: b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust??? (ransack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack »</TD></TR><TR><TD CLASS="quote">not sure about EG hatch, but im pretty sure it wont
Same with EG I assume....</TD></TR></TABLE>
you will need an extension pipe welded on.
Re: b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust??? (whoDAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT »</TD></TR><TR><TD CLASS="quote">
you will need an extension pipe welded on.</TD></TR></TABLE>
i'm not sure... i was using either a b18c1 or b18b header for a few weeks when i swapped engines, it bolted up to my stock cat and catback with no modification. i have an ej1 but i think the exhaust is the same dimensions as a hatchback up untill the axle-back muffler section.
the ek midpipe is not the same size as an eg, dont go based on that.
if someone can tell me the difference in stock b series exhaust manifolds, i can check which one i was using.
Re: b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust??? (euclid)
it wont fit the bolt alingment is different one is (--) that way and the other is (/) like that at an angle
Re: b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust??? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">it wont fit the bolt alingment is different one is (--) that way and the other is (/) like that at an angle</TD></TR></TABLE>
i was using a gsr manifold then, the bolts were staggered (/) like stock.
at least we figured out a gsr is bolt-on.
Re: b18b into my EG hatch. Does stock b18b header bolt up to stock DX exhaust??? (94hondaLS)
Ok so if I use the LS stock cat it will? But if I use the GSR header it also will... ok I think we got this guys... almost at this part of the process... Just trying to avoid getting a ticket since the muffler shop is like a half hours drive from my house...
DougNuts
02-24-2005 07:20 AM
