caliper bridge bolt stuck
Old 06-28-2011, 10:57 PM
efeher's Avatar
Default caliper bridge bolt stuck
the two bolts that hold the caliper bridge on are rusted/overtightened stuck. i tried a 22" breaker bar and an impact wrench with penetrating oil, any other ideas?
Old 06-29-2011, 12:20 AM
Joeynapp's Avatar
Default Re: caliper bridge bolt stuck
Heat ALOT of heat. Propane torch hold on the bolt for about 3-5 mins then use the breaker-bar. Just don't burn your self or the hose. Heat will become your best friend in situations like these..
Old 06-29-2011, 01:03 AM
efeher's Avatar
I thought heat may work, i was just worried because the axle boot and the rubber caliper bushing are close. I was planning on covering these with a wet towel, are there any other parts i should protect?
smmcla
Suspension & Brakes
11
04-13-2020 04:52 AM
732xghost
06-20-2009 04:55 PM
deeweezy187
05-13-2006 09:29 PM
EGhatch33
Suspension & Brakes
24
01-02-2006 10:01 AM
AndrewD
01-22-2005 12:10 PM
Quick Reply: caliper bridge bolt stuck
