b18b in a 92-95 ex
b18b in a 92-95 ex
a friend of mine is getting ready to do this and I was wondering if there were any common problems, mishaps, or anything to look for while performing this swap.....???? Thanks in advance
Re: b18b in a 92-95 ex (tourhcky)
im doing this swap on friday and the only thing i know thats a problem is the cat is too short so you either need to have it extended or use a test pipe. other than that it drops right in and is plug and play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tourhcky »</TD></TR><TR><TD CLASS="quote">a friend of mine is getting ready to do this and I was wondering if there were any common problems, mishaps, or anything to look for while performing this swap.....???? Thanks in advance</TD></TR></TABLE>
Only common problem is usually idiots trying to do it with no mechanical skill at all. Do your homework and found out exactly what is involved(ie what motor mounts and wiring harness are needed). If you have any mechanical skill(that involves knowing more then how to change oil)the swap is pretty straight forward. Any particualr questions you may have.....shoot away?
dsmarefaster
04-11-2005 02:48 PM
