B18A1 into EG
B18A1 into EG
What's the best route to get a 91 b18 into the EG to work properly? I know the 90-91 were OBD0, could I switch to an OBD1 dizzy and wiring harness and install with a OBD1 PR4 ECU, or is it more compluicated than that?
Re: B18A1 into EG
****ING SEARCH!!!
Its not that hard
94-95 OBD1 Integra ECU (p75)
94-95 OBD1 Integra Intake Manifold
94-95 OBD1 Integra Axles/halfshaft
94-95 OBD1 Integra Or Stock Engine harness
94-95 OBD1 Integra T bracket
94-95 OBD1 Integra shift Linkage
94-95 OBD1 Integra Post Mount/Driverside mount
94-95 OBD1 Integra B18b1 Dizzy
Any B series Hydro Tansmission
Look a couples out!
https://honda-tech.com/forums/showth...9#post37649399
Its not that hard
Look a couples out!
Re: B18A1 into EG
If i knew I would tell you cause I absolutely hate the first post that people respond to is "why don't you search." It's just like shut up if your not going to help. I swear people sit around and just can't wait to tell people to search. This is a tool just like searching is.... get used to it.
anywhoo I found the best way to search is use your standard google browser and after what you want to search for write honda tech.... Like b18a1 swap eg honda tech. hope that helps
Re: B18A1 into EG
****ING SEARCH!!!
Its not that hard
Look a couples out!
Its not that hard
Look a couples out!
lileghatch
23
03-31-2009 08:31 AM
