B18 question
B18 question
92 eg hatch with a b18b1 swap. Purchased the car with a blown b18b1, swapped in a 94 b18b1. The harness is hacked to death, so I am getting an unhacked cx harness. I've read every thread i could find, and many say they are plug n play, jusst want to make sure this is fine to do before ordering my new harness. The new engine is obd1, ecu is p75 obd1, and I am getting an obd1 harness. Does any wiring need changed/extended? The car currently has a one wire o2 sensor, anything need changed for that? Thank you for the help.
Re: B18 question
I feel like there was a certain year of CX uses a single wire o2 sensor. Check on that, if it is a one wire o2 you will need to fix that.
I believe the VX used a 5 fire o2 sensor.
Otherwise, I think it should be plug and play.
Re: B18 question
I think the B18B1 uses the 4 wire O2 (Heated Narrow Band).
If I recall the B18B1 came from the CRV, but I don't remember the years. You might be able to locate digital scaned versions of the CRV helm's manuals and compare it to the 92-95 helm's manual.
PhatwhipsJDMkits
10
11-11-2004 06:38 AM
DevinW
03-27-2003 06:56 AM
