b18 in EG
Munkyw3rkz.webs.com
1 Post
b18 in EG
i have a 93 4dr and was thinking about a a B18 in it...what will i need other then the motor,tranny,axels and ecu...harness too ....i currently have a D15....i did a serach but no luck...thanx
Re: b18 in EG (Hammett)
If you're referring to a B18B, make sure you have all the mounts from your Integra engine. It's a direct bolt-in, but not with your stock D15 mounts. I made the mistake of misreading, and needless to say my car was parked for a while!!!
Andre
Andre
New User
Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">shift linkages</TD></TR></TABLE>
Yeah, but you only need one...
94 integra shift linkage...
Munkyw3rkz.webs.com
1 Post
Re: b18 in EG (TotalBoost)
ok so with the stock mounts off the B18b it ill drop right in. and the wireing is the same so all i need is the axels,tranny,motor w/mounts and ecu.... correct?
Re: b18 in EG (ecko_rican)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecko_rican »</TD></TR><TR><TD CLASS="quote">ok so with the stock mounts off the B18b it ill drop right in. and the wireing is the same so all i need is the axels,tranny,motor w/mounts and ecu.... correct?
u need the integra shift linkage too. if the b18b is from a 94-01 integ, the engine harness will plug directly into you car. if the integra is 96+, you'll need to get a 94-95 LS ecu
does it work if you are using these mounts.....
driver side upper mount from the integra
driver side lower mount from the civic
passanger side lower mount from the integra
passanger side upper mount from the integra
what about the lower center mount? does it have to be the integra one or would the civic one work???
hondaguyexsi
09-23-2005 03:36 PM
Xgen
14
06-04-2005 08:24 AM
TurboSohc
03-02-2003 03:42 PM
