b16b worth it?
b16b worth it?
am in the process of buying a swap for my ek i was looking at a b16b swap for a good price, how does this swap compare overall to a integra type r or gsr swap?
Re: b16b worth it?
depends on what you are trying to accomplish, street, track, DD???
b16b are nice just to say you have a CTR swap or i can rev to 9k, but as terms to power possibilities, pretty limited compared to a GSR
Re: b16b worth it?
Code---Disp (cc)---------HP--------Torque----Comp---Bore--Stroke---------Found in-------------
B16B----1595---------185@8200--118@7500---10.8:1--81-----77.4------1997-2001 CTR (JDM)
B18C1---1797---------170@7600--128@6200---10.0:1--81----87.2------1994-2001 Integra GSR
B18C5---1797---------195@7800--130@7600---10.6:1--81----87.2------1997-2001 ITR (USDM)
B18C5---1797---------210@8100--130@7600---11.0:1--81----87.2------1997-2001 ITR (JDM)
As you can see, the CTR has more HP than the GSR, but less TQ.....
Re: b16b worth it?
^^^nice sig quote
Re: b16b worth it?
i actually personally believe it's the other way around, ITR swaps are absolutely beautiful, don't get me wrong, but in the long run, the GSR's potential is far greater, out of the factory, the 98+ spec ITR does have the most power, but because of it's high comp, it's limited in power possibilities, but like i said before, it all depends on what your goals are.
^^^nice sig quote
^^^nice sig quote
I dunno, im just sick of seeing kids with GSR swaps everywhere. And a JDM ITR with 210 HP? thats pretty good all motor power considering its stock. You could put out 220WHP probably with a set of better plugs, a header, intake and possibly a tune. Thats pretty decent all motor. or you could spray a 50 shot in it on top of that. Its high comp so it will be pretty good with NOS.
Re: b16b worth it?
Whoa whoa whoa....pass the pipe dude if your trying to say that plugs, header, intake, and a possible tune will make 220whp!!
All cars loose about 12-15% of power transferring from where its measured at the flywheel to when it gets to the wheels....so, lets SAY 13%....
some simple math:
210 x .87 = 182.70
So now lets give the benefit of the doubt and say tonto did an extra nice job on your hand ported head and instead of having 182whp youve got 190whp...(i doubt it)....you will NEVER pick up 30WHP from the most basic mods out there....never
im not bashing, please dont take it that way. I just dont want you to spend $600+ dollars for a tune or think your makin that much power. The mods you have listed arent anything major enough to require a tune. Better spark and a little more air flow will simply just be a little push from behind with some more absolutely memorizing noise coming from under your hood.
Get the ITR swap, put it in with an intake and some plugs...good start...if you get a JDM ITR then dont replace the headers unless there f**ked up...the intake manifold and headers are perfectly port matched from the factory i believe....
NOS =
you know what happens when you put NOs on your car???
put it in, drive it and be happy with it...idk if you have driven this motor but it will rock your world for sure if you havent...GL
Dc2
Re: b16b worth it?
guys stop looking at hp figures there all very confusing, start looking at KW figures as they are more accurate, you see the hp,bhp,ps are all different and when you compare the jdm 98+ itr to the usdm itr its not actually putting out 15 more hp, its rather only a 5.5 hp difference(146kw vs 150 kw) thats why youll see most sites have considered that difference and rerated the jdm at 200hp which is the correct hp figure for the usdm market!
as for the swap, the b16b is an incredible motor,it loves to rev,its great in endurance races,its output is the highest per lt among b series, but that about where it ends,its expensive,its lacking tq,its not built to run on our shity u.s gas,its got almost no potential in tuning due to the fact that its already pumping out a number soo high and that its using almost every performance upgrade from stock(header,cat,catback,intake manifold,tb,ecu,plugs,pistons are all modified and if modified any futher do not yield any substantial gains).
considering all that,and that a ctr go's for above 3500,an itr above 4k I would have to say your best bet is the jdm gsr(sir-g or whatever) at an average 2.5-3k. its just 3 hp shy of the ctr 183hp but it has alot more tq, a better powerband,more dissplacement therefore more potential specially considering it makes 100hp per lt vs almost 114,its cheaper and not to mention its probably beat on alot less than the ctr!
Re: b16b worth it?
Just build a LS vtec...the LS has a 89MM crank and with p30 or JDM type R pistons and good cams you will make the make the power of JDM type R or more...but you have to know what your getting into
Re: b16b worth it?
The B16B and B18C use the same deck height block, but a shorter stroke. I say put high comp pistons in a B18C1 block and a longer stroke crank, plus the CTR head if anything.
Re: b16b worth it?
some simple math:
210 x .87 = 182.70
NOS =
Dc2
some simple math:
210 x .87 = 182.70
NOS =
Dc2
I dunno much about the type R but i just listed some normal upgrades that people do to make more HP NA. ALthough i think NA honda's are worthless. To make any decent power N/A you will sacrifice a nice amount of gas mileage.
Re: b16b worth it?
a CTR head has a higher CCV so what he would do is take the CTR head internals and put them in a GSR head. That would make more power than a CTR head.
Re: b16b worth it?
Dude if you found it for a great price get it. Those are rare to get, and you could always flip it if it's not what you want. Plus the tranny is great. Anything bought for a great price, is more money in your pocket if you sell it proper later
Besides if you've never tried it, who knows you might keep it
Re: b16b worth it?
cost is the first thing i would look at. with 97 ITR swaps selling for $3500-3600 shipped and the CTR swap around $3400 shipped it's a pretty easy choice to go with more displacement. GSR swaps are still going for $2900ish with the LSD which is only 600 or so less than the ITR. there is no way $600 will get a GSR to ITR power levels with anything besides NAAAWZ. hey. come to think about it, that movie comes out friday
Re: b16b worth it?
Re: b16b worth it?
i have a B16b in my eg for over a year now with just basic bolt ons and its a blast to drive around. i have a 8 lb flywheel and n1 crank pully rippin it up to 9 grand makes me smile everytime, launching the car sucks, if you can pick one up for a good deal and want a fun daily driver/ autocross car DO IT!
Re: b16b worth it?
UPs: nice gearing in the trans... cheap-o factory LSD... red valve cover.. decent ebayable cams... stock (you don't have to **** with it and it'll be turn-key reliable, especially since your not that much of a technical guy since you asked this)
DOWNs: torqueless... 10000000 rpm before it grows any ***** (and tiny ***** still)... expensive ****... all the 'TYPE ARRR' **** you are paying for will get replaced if you try to get anything more out of it...
but i'm sure you'd enjoy the **** out of it. its a fun motor especially in a lighter car. fun fun fun
