Is the B16B lighter then the B18C5?
Old 05-26-2003, 02:51 PM
B16A2-EM1's Avatar
Default Is the B16B lighter then the B18C5?
Yes or no, I don't feel like searching. Here is a Beer
Old 05-26-2003, 02:58 PM
Hash Browns's Avatar
Default Re: Is the B16B lighter then the B18C5? (B16A2-EM1)
As a whole, they should be approximately the same weight.
There may be minor weight differences between the two engines in terms of their accessories, ie: the CTR crank pulley is supposed to be lighter than those used on its other Bseries counterparts. The bare blocks and heads themselves should be the same in weight as they are pretty much the same part.
Old 05-26-2003, 02:59 PM
navin's Avatar
Default Re: Is the B16B lighter then the B18C5? (Hash Browns)
I'm wondering would the B16B have a shorter block height than the b18c5... I know B16a's do, not sure if the b16b's use the same block..
doot doot
Old 05-26-2003, 03:00 PM
Dancing is Forbidden's Avatar
Default Re: Is the B16B lighter then the B18C5? (navin)
theyre the same engine, just the b16b is destroked to get a better rod stroke ratio
If im wrong shoot me
Old 05-26-2003, 03:08 PM
Mar_DC2's Avatar
Default Re: Is the B16B lighter then the B18C5? (EF9_SiR)
i think youre right, from what i can tell theyre essentially the same block, the B16B is just destroked to lower the displacement, but they gave it very high dome piston's to keep the compression ratio up. i might be wrong though.
Old 05-26-2003, 03:11 PM
allmtr's Avatar
the b16b has 7mm more deck hight than the b16a, which is the same as the gsr, ls, and itr.
Old 05-26-2003, 03:42 PM
navin's Avatar
Default Re: Is the B16B lighter then the B18C5? (allmtr)
thanks for clearing that up for me
Old 05-26-2003, 05:08 PM
ill phil's Avatar
Yep same deck height as b18c. Unless crank is counterweighted differently, I think it would be the same weight as an ITR motor. FYI not all CTR's came with the N1 crank pulley. I have a B16B and its the same crank pulley as my b16a was.
Old 06-03-2003, 07:27 PM
GOLDBERG's Avatar
Default Re: Is the B16B lighter then the B18C5? (ill phil)
what crank do you use to make the b16b an itr essentially?
Old 06-03-2003, 07:35 PM
Default Re: Is the B16B lighter then the B18C5? (GOLDBERG)
probably an ITR crank, and rods and pistons
Old 06-03-2003, 10:49 PM
ill phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">probably an ITR crank, and rods and pistons</TD></TR></TABLE>
Correct, or just use a GSR crank, rods and your CTR pistons and have something a little cheaper and higher comp.
Wytek9
04-23-2008 09:32 AM
labatt50
09-24-2006 12:28 PM
SilverEk3dr
02-17-2006 09:42 PM
ghettoracer
05-10-2004 06:29 AM
CivicCXG
01-21-2003 10:06 PM
Quick Reply: Is the B16B lighter then the B18C5?
