b16b into 92 vx help
Old 09-25-2004, 05:27 PM
10 psi's Avatar
Default b16b into 92 vx help
Is this a straight swap with no extra parts needed except (timing belt, etc)?
Old 09-25-2004, 05:39 PM
pwrofdrm's Avatar
Default Re: b16b into 92 vx help (10 psi)
that depends whether you're buying a "complete swap" or not.
Old 09-25-2004, 05:48 PM
spyderracing's Avatar
Default Re: b16b into 92 vx help (lax1185)
Yer gonna need a complete swap. List what you're getting and maybe we can tell you.
Old 09-25-2004, 05:51 PM
10 psi's Avatar
Default Re: b16b into 92 vx help (spyderracing32)
i planned on getting the complete swap from hmotorsonline
Old 09-25-2004, 05:52 PM
Built B16A's Avatar
Location: hittin corners so hard you can taste my rims..
what about the wirring side...
say he crated a 2nd GEN B16A W/ hydro tranny. (axles, shift linkage, *P30 or whatever ECU 2nd GEN B16's had.* mounts, and converted his wirring harness over.
what wirring would be involved from going from 5 WIRE o2.. to the common 4 wire HEATED O2?
Old 09-25-2004, 05:55 PM
Default Re: b16b into 92 vx help (Built B16A)
Just make sure you get the right year for your car. OBD swaps are no fun. Other then that, a complete swap is just that, a complete swap. You're getting the tranny with it right?
BTW built..... I <3 your hatch. Your car made me dream about gettin a set of mr-5's for my hatch.
Old 09-25-2004, 05:58 PM
10 psi's Avatar
yea its comes with everything and its obd-1 just like my car. I was wondering if the wiring is tricky or just plug and play?
Old 09-25-2004, 06:00 PM
Should be plug and play. I dunno about the o2 sensor, if ya throw a code when ya start it up you'll have to rewire that. It won't exactly adversly effect the way your car runs either. You should do it in the long run though..... I still need to rewire my o2 sensor for my D15B.
john d
Texas -OK -LA (Sales)
09-07-2006 09:35 AM
codybob
15
02-10-2006 12:35 PM
hondaracing1
13
03-30-2005 07:26 PM
EFing8
12-04-2002 04:34 PM
Quick Reply: b16b into 92 vx help
