b16b into 200 civic dx harness questions
alright what harness should i use the stock harness for the z6 or shouldi use the jdm b16b harness. last night we tried using the b16b harness but the motor didnt fire up. so right now were putting in the z6 harness and what else will we have to wire other than vtec knock sensor and pressure switch
alright, so the stock harness will work? i just need switch out the distributer cables from the jdm harness to the y7 harness and then wire all the misc stuff
Go Tigers!
for the most part I would think so. Unless your b16b is obd2a.
most things should wire straight up with that harness you'll probably have to wire in vtec and maybe a knock sensor.
I don't know all the minute details off the top of my head about wiring schematics for EKs but this should point you in the right direction, someone else will prob chime in and be able to give you a more accurate and definite answer though
alright about the distributer part the actual distributer plug has 9 wires and the harness has 8 wires.. were gonna swap out the pluyg from the b16b harness cause it pllugs right in but which wire do we not use
