B16A2 Swap
B16A2 Swap
I want to do a B16A2 swap on my 97 LX sedan but I was wondering how much it would cost me including the engine, ecu, manual tranny, the whole bit. A ballpark figure will help in order to see if I need to save more money.
Re: B16A2 Swap (shizznittz)
my friend just got a b16 into his 91 crx. originally it was supposed to cost 4200 for everything including labor, but......he hadn't thought to change the timeing belt, water pump, spark plug ****.....which is how his 100% startup warrenty works. well after that the oil pump went bad so that had to change, his header wouldn't fit so he had to buy a new radiator and fan. not that he's complaining just the little stuff adds up. his grand total came to like $5600. so i'd say 4,000 to 6,000 that's my ball park.
good luck
sorry so long
good luck
sorry so long
Solbros Owns Me
Re: B16A2 Swap (civic-si-2000)
B16A2, as in 99-00 Si or a 2nd gen SirII JDM B16???
You could spend anywhere from 2 grand up to 4 grand for the entire engine/ecu setup with mounts, and then expect to pay 2-500 for labor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizznittz »</TD></TR><TR><TD CLASS="quote">I want to do a B16A2 swap on my 97 LX sedan but I was wondering how much it would cost me including the engine, ecu, manual tranny, the whole bit. A ballpark figure will help in order to see if I need to save more money.</TD></TR></TABLE>
hmmmmm....hit up http://www.prostreetimport.com
they have all prices listed there and they do great work...
they're off of the 5 fwy on Artesia...
1 Post
if your doing it yourself it had better no cost you any more than three grand. You can find the motor on ebay for dirt cheap....or the parts trader thats a good one too. If you are having someone else do it, your looking at some serious labor...One thing for sure, do it right the first time though. Good luck with that swap.
Location: Your really lame if you dock my points, WA, 98033
Re: B16A2 Swap (civic-typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-typeR »</TD></TR><TR><TD CLASS="quote">i am doing the same swap exept with type r tranny and i want to know what wiring i might need, but my car is an ex(civic 97) </TD></TR></TABLE>
should be pretty much plug and play. for you. just move the harness around to make it fit all the sensors. i didnt have to cut or extend one wire in my swap. also look into getting an obd1 ecu and jumper harness.
I got my b16a2 from an ht member for $2300.
I see them going for anywhere from 2k-4k like someone already said. Awhile back i got a quote from a local shop for a b16 installed for $3k.
Re: B16A2 Swap (HyBriDcxR)
I put one of my swaps togethether for cheap.. 200 for a legit 00 si block from a local shop(was a customers that went b20 vtec), 900 for axels, ecu, wiring harness, head and tranny.. and 86 for OEM honda head gasket.. So about 1200 for the complete swap & I installed the ****** myself
Re: B16A2 Swap (Slammed Si)
theres a guy that has a legit 2000 Si B16 swap complete for 2500obo....heres the link: https://honda-tech.com/zerothread?id=648292
Good luck bro...this is a smoking deal. If I were you I'd jump on it.
Local too!
Local too!
If your doing the swap your self id say about 2-3 grand its all depending on how much you get the motor for , and what all you need to replace. If your haveing a shop put it in for you i say probably expect about 500-700 in labor
ne1 from around philly?? How much does a b16a2 engine and transmission swap cost??..tranny from an a
civickid32
08-31-2004 09:40 PM
