b16a2 striped cam side motor mount hole
oke guys i was just puting together my b16 when i striped my cam side motor mount bold its the upper one on that in front k so i torq it to spec and it just went skip b4 it clicked at 40ftlbs k it has some thread left should i just tap it out and up side it and use a bigger bolt or should i get a stud and use a nut insted so it wont strip next time ??? i need to know
Re: b16a2 striped cam side motor mount hole
Your going to have to explain this a little more in detail. Did you strip out the threads on the block or the motor mount?
probably have to replace the broken part, or if you really wanna be ghetto i guess you could use a long bolt same size with a nut on the end Lol
deerman2701
10-19-2012 01:17 PM
