b16a2 HEAD.. Need some info !
Getting the ECU chipped and planning to rev to 8.8-9k on a stock b16a2 HEAD
Not really sure if they can handle those revs.. btw I have a b20 bottom end ( b20v )
Should the Valves be replace to something like typeR valves because they are lighter and can handle higher revs? or would the stock valves be fine.
thx ahead for some info
Re: b16a2 HEAD.. Need some info ! (ReFreSh)
id worry more about the bottom end. If its a stock B20 bottom youll be spinning those rods first trip to 9 (if it makes it that high).
Re: b16a2 HEAD.. Need some info ! (Luserkid)
forgot to add
built bottom end
JE pistons
Eagle Rods
b20 crank
almost new everythangg rod bolts, studs, bearings
now back to my question
built bottom end
JE pistons
Eagle Rods
b20 crank
Re: b16a2 HEAD.. Need some info ! (SiRek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRek4 »</TD></TR><TR><TD CLASS="quote">i
get hondata as well, the whole chipping the ecu things is garbage.</TD></TR></TABLE>
and where did you get that info from??
CHIPPED p28 ECU ON CROME FTW
Re: b16a2 HEAD.. Need some info ! (TheSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSi »</TD></TR><TR><TD CLASS="quote">
CHIPPED p28 ECU ON CROME FTW </TD></TR></TABLE>
Re: (ReFreSh)
Type R intake valves are a weak link IMO. The dual valve springs would be safe around 8500 rpm.
After that all I can say is Good luck and:
Chipped P28 on Crome Pro FTW!
Re: (ReFreSh)
The valves should be fine. You can replace springs and such without removing the head just have air pressure holding valves up or use the string method.
B16 stock internals and you don't want to rev much over 8200 rpm
dont talk anymore.
dont talk anymore.
if you gonna rev up high
get some springs/retainers...for safety
you dont wanna brake them stock springs
and float your valves....
as for the redlining/revving hi...you do need to change your ECU..get chipped or something..
stock head is good up to 8k...but the risk is high..it all depends on how hard you drive your car....revving up to 8k once in a while is aight...but after 8.5k rpm and up,the power band of the stock camshafts are about the same, youll just gonna break your springs or whatever, youre just putting too much stress on the head, but if you put at least a typeR camshaft or stage 1 camshafts then, youll feel the difference...
dont waste your money on some crazy ****...
Guest
Posts: n/a
Re: b16a2 HEAD.. Need some info ! (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson »</TD></TR><TR><TD CLASS="quote">
dont talk anymore. </TD></TR></TABLE>
i wont talk anymore if you would read some more. getting his bottom end built and wanting to rev to 9k, on a chipped ECU. oooooooook, thats good advice. NOT!
dude, get good cams, and valve train, hondata S200, and your car will be fine. I promise if you listen to all these clowns on here your car wont get far.
Chipped ECU's are trash next to hondata.
Chipped ECU's are trash next to hondata.</TD></TR></TABLE>
HAHAHAHHAHAHAH!
This guy funny..
Go ahead and keep paying $500+ for that.
When others can get the same functions for...free?
Btw theres are ALOT of people 400hp+ that tune on crome.
HAHAHAHHAHAHAH!
This guy funny..
Guest
Posts: n/a
Re: b16a2 HEAD.. Need some info ! (Boostedb20EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 »</TD></TR><TR><TD CLASS="quote">
HAHAHAHHAHAHAH!
This guy funny..
Btw theres are ALOT of people 400hp+ that tune on crome.</TD></TR></TABLE>
jokes on you cause S200 is nowhere near 500 and show me a car making 400+ on chrome.
HAHAHAHHAHAHAH!
This guy funny..
wow, you are a ******* moron.
we have 500+hp cars here on crome pro.
you dont need to spend lots of money to go 10s
god forbid someone uses a LS turbo motor, on crome, with stock mounts and axels to go 10's
https://honda-tech.com/zerothread?id=1440420
Guest
Posts: n/a
Re: b16a2 HEAD.. Need some info ! (spoolinegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinegsr »</TD></TR><TR><TD CLASS="quote">wow, you are a ******* moron.
https://honda-tech.com/zerothread?id=1440420</TD></TR></TABLE>
what are you talking about dick head?
who said anything about an LS turbo going 10's?
your real dumb huh? and im sure you have cars making 500+ on chrome, yeah yeah yeah, put one of those cars on hondata and see what it makes clownshoe.
You belong on Hondatech.com
Guest
Posts: n/a
someone please read this again.
1st he says "we have" like its his shop
2nd he says "you dont need to spend lots of money to go 10s"
can you believe this?
the guy he linked to does not have a stock ls motor, the bottom end is sleeved and the head is built.
you should read your own links first spoolinegsr, last time i checked, getting a head built and a block sleeved isnt cheap. your about a dummie!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRek4 »</TD></TR><TR><TD CLASS="quote">what are you talking about dick head?
You belong on Hondatech.com </TD></TR></TABLE>
WTF? you obviously cant read/ comprehend...
