b16a2 Dyno Numbers
Old 04-22-2003, 10:20 PM
jus f0 dekarayshunZ
ciRcuitJerk's Avatar
Default b16a2 Dyno Numbers
i searched but i didnt really find what i was looking for...what kind of number do b16a2's usually pull with i/h/e...i want to know what i can expect since i will be dynoing for the first time..thanks in advance
Old 04-22-2003, 10:21 PM
eg_nezay's Avatar
Default Re: b16a2 Dyno Numbers (CiRcUiTsi)
around 140-145~~
Is there a price for the one that comes the closest?
edit- cause its USDM
Modified by eg_nezay at 8:21 AM 4/23/2003
Old 04-22-2003, 10:23 PM
sshaikh01's Avatar
Default Re: b16a2 Dyno Numbers (eg_nezay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_nezay &raquo;</TD></TR><TR><TD CLASS="quote">around 145-150~~
Is there a price for the one that comes the closest?</TD></TR></TABLE>
thats very little loss of power.
don't the SIRII have 168 HP
Old 04-22-2003, 10:25 PM
IM ALL BOB's Avatar
Default Re: b16a2 Dyno Numbers (sshaikh01)
were talking to the wheels not to the crank/flywheel.. there are always drivetrain loses
Old 04-22-2003, 10:26 PM
jus f0 dekarayshunZ
142 stock hp claimed to the wheels i believe
Old 04-22-2003, 10:28 PM
eg_nezay's Avatar
I forgot James, u not JDM boi, LoL.
usdm= 160
jdm= 170
So James, my numbers drop to, 140~~
Old 04-22-2003, 10:34 PM
v00tecsi's Avatar
USDM b16a with I/H/E can range from 140-150WHP. Depends on the car, and equipment you choose.
Old 04-22-2003, 10:58 PM
Broken Gearbox's Avatar
Default Re: b16a2 Dyno Numbers (v00tecsi)
140-145
Old 04-22-2003, 11:45 PM
SpoonEK2's Avatar
I got 141hp with an AEM CAI and a random tech cat...stock header/exhaust.
Old 04-22-2003, 11:51 PM
SpoonEK2's Avatar
Default Re: b16a2 Dyno Numbers (SpoonEK2)
Oops, forgot to mention a friend got 155hp w/ IHE...
Old 04-23-2003, 04:58 AM
Former Moderator
B18C5-EH2's Avatar
My fiancee's B16
A2 with i/h/e and HASport-chipped P28 did 143whp with 102 ft-lbs. of torque.
My pal's second-gen B16A (170hp) pulled 151whp with only mods being Dc header and exhaust with the airbox pulledm open on that run.
Airbox on it pulled 149whp.
Old 04-23-2003, 06:16 AM
1999all_motoR_teg's Avatar
Default Re: b16a2 Dyno Numbers (B18C5-EH2)
My second gen B16a(170hp) pulled 155.2whp with I/E and skunk2 chipped ECU.
Now with CTR cams,ITR valvetrain,APEXI VAFC and AEM cam gears with above mentioned mods hoping to hit 165-170whp.
Old 04-23-2003, 06:44 AM
jus f0 dekarayshunZ
Default Re: b16a2 Dyno Numbers (CIVICVTI2)
i guess theres a pretty big difference between the usdm and jdm version...im sad now
Old 04-23-2003, 06:53 AM
rodrez.'s Avatar
I never had a 2nd gen, but back in 96 when I dyno'd my old 1st gen B16 with I/H/E and sprockets, it hit 155hp, 112 tq.
Old 04-23-2003, 06:55 AM
Former Moderator
B18C5-EH2's Avatar
Default Re: b16a2 Dyno Numbers (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">I never had a 2nd gen, but back in 96 when I dyno'd my 1st gen B16 with I/H/E and sprockets, it hit 155hp, 112 tq. </TD></TR></TABLE>
...then you had the strongest B16a I've ever seen with such mods.
I'm thinking the previous owner put cams and/or some other unknown mods, because those numbers are way high for a first-gen B16A.
Old 04-23-2003, 06:57 AM
137's Avatar
go to clubsi.com's main page they have a bs tech section with the stock dyno numbers on it,...
Old 04-23-2003, 06:59 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm thinking the previous owner put cams and/or some other unknown mods, because those numbers are way high for a first-gen B16A.</TD></TR></TABLE>
I think it was actually the tuner. Aries Dizon of Dynamic Autosport is well known for making power. At that same time, my friend was dyno'ing his 4 door w/a 1st gen, I/H/E wired up to the newer gen 2 ECU and a milled head, he made 161 w/116tq. Tuners are everything.
Old 04-23-2003, 07:03 AM
Drews Bitch's Avatar
here's a fellow DFH'rs dyno print out. his b16a2 has some build time into it though.
166 whp and 115 torque
https://honda-tech.com/zerothread?id=451067
Old 04-23-2003, 07:05 AM
cruzersi99's Avatar
It could also be the dyno...
Cruzer
Old 04-23-2003, 07:13 AM
rodrez.'s Avatar
Default Re: b16a2 Dyno Numbers (cruzersi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruzersi00 &raquo;</TD></TR><TR><TD CLASS="quote">It could also be the dyno...
Cruzer</TD></TR></TABLE>
Very true. A few months later I redyno'd at AEBS, an in ground dyno, and with a bigger, 4-1 header, it was a prototype from Hotshot, and was making 158hp, but 109tq, possibly the header, but I can't say for sure.
Old 04-23-2003, 07:16 AM
DragII's Avatar
but there was something wierd stuck to my exhaust manifold
Old 04-23-2003, 07:34 AM
pbomers's Avatar
Default Re: b16a2 Dyno Numbers (Skeety Gonzales)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skeety Gonzales &raquo;</TD></TR><TR><TD CLASS="quote">
but there was something wierd stuck to my exhaust manifold </TD></TR></TABLE>
LMAO...i think it's a snail....check...sometimes they get stuck up in there!
Old 04-23-2003, 08:17 AM
AzG35's Avatar
Default Re: b16a2 Dyno Numbers (TinyCRX)
I/H/E on my old B16a2, I put down 142hp and 103 torque. The torqueless wonder.
jus f0 dekarayshunZ
Default Re: b16a2 Dyno Numbers (AzSi22)
so i should expect between 140-145 with i/h/e...
Old 04-23-2003, 08:24 AM
SpoonEK2's Avatar
We all know you've got more than a B16A James!
Quick Reply: b16a2 Dyno Numbers
