B16A swap
B16A swap
I have a '92 civic si, I swapped in a B16A and used the si harness ('92) with the P30 ECU, and the B16 doesn't have a map sensnor on the throttle body, so that plug is just sitting there. I'm throwing a code, I haven't had time to check the code, but I was wondering if that would be the problem?
Re: B16A swap (RedStar101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStar101 »</TD></TR><TR><TD CLASS="quote">it could be anything, if you had time to make this thread, you had time to check the code</TD></TR></TABLE>
lol
its probably throwing a MAP code. easy fix, just take off the MAP from your old swap (located on the TB), plug it with the correct wire harness plug, then take a vacuum line connect it to the nipple on the MAP to the nipple on your B16A TB and problem solve
lol
well I would tell you but it doesn't flash any codes? when I put something in the pin and turn the car to the on position, the light just stays lit up, it doesn't flash any codes
Re: (newbiehonda_05)
You arent checking it correctly. Get a paper clip and read the FAQ at the top of the page to see how to check your code. 1 short flahs = 1 and 1 long flash = 10.
Re: B16A swap (tdocrx)
well then I'm checking it right, but it just stays lit up, it wont go off or flash codes, does anyone know of this problem, and if so how to fix it
Powered By Garrett
12-13-2005 09:16 AM
Grip
04-14-2005 02:39 PM
racecarpete
01-15-2005 08:55 AM
