B16a stalled once at idle now cutting out while driving
I was at a stop light and all seemed normal I was watching all of my sensors on s300, after about 30 seconds at idle it died like I shut the key off except all the lights stayed on and none of the values other then rpm changed , would not restart. Pushed it out of traffic and waited 3 or 4 minutes then it restarted but was dumping fuel running 10+afr. After it cleared up it ran fine for a week or 2, I put a turbo kit on it and drove it for another week making boost, running perfect, it still runs fine most of the time but at low throttle intermittently it will lean out for 5 seconds all the way to 16+ and cuts out and then it catches up and afr goes back to 13.5-14, car is on open loop and normally runs very well. Car is an eg hatchback with a stock b16a with an ebay turbo kit running hondata s300 v3. I'm thinking the fuel pump may be dieing but it runs perfect in boost at higher rpm the issue seems to be at lower rpm. I tried searching for the answer but can't find anyone with a similar issue, any suggestions?
descartesfool
05-22-2008 02:38 AM
