b16a rebuild: itr conversion?
hey peeps i opened this thread to get some professional help i got a b16a that i want to build up i heard from this one guy that i can do a itr conversion and make it a 1.8L thing is this will be my first engine build try. of course i got someboby to help me build it but i need help to know what is the best engine set up to get 200 or more hp im kind of a newbie at this so please i will take any advice into consideration i want to build a good engine that i can be able to use on street so im not trying to go all crazy i want to keep it as much oem as possible so let me know and please be as especific as you can i mean like wut kind of headbolts to use cams rods and pistons also i will be converting a cable tranny into a hydro so let me know about your experiences with that also thanks in advance for all the inputs ...............
Re: b16a rebuild
sorry to tell u this but the lil 1.6 wont go to a 1.8 the itr and ctr block are the same, same as a gsr too. its taller than the b16. the only thing u could use is the crank... the stock rods on the b16 are hella short.
200hp on b16? u trying to do this n/a or turbo?
u would really be pushing a b16 to make 200 whp N/A. a tubro build is what i'd do. cheap-e ebay turbo kit, gets u all the piping and such then spend a few bucks and get a better turbo.
Re: b16a rebuild
im trying to go n/a on it i dont mind if i dont get the 200 mark but just want a good set up i want to use wat i got if anything i might just go after market after all im in no rush thanks for the info i really thought i could make it a 1.8 good to know thats not possible ill scratch that off my list oh well any thing else
Re: b16a rebuild
you can use a b17 crank and prolly go with itr pistons or p30 im not sure about the clearance and get some ctr cams im pretty that would be a good setup..some guy with a b17 crank was running high 13s with a b17 crank not sure what else he had but he had traction problem so it was fast...at sacramento race way
Re: b16a rebuild
200whp isn't too hard. it isn't cheap but nothing radical. just alot of headwork and some big cams. but keeping it all in the OEM range would be pretty difficult.
be better off trying in the all motor section but be specific.
Re: b16a rebuild
Doing a all motor build is pointless IMO, your not going to make power. Go turbo and you will be happy with it.
Re: b16a rebuild
having traction problems doesnt make the car fast. It makes your tires shitty. I make 300+WHP on my setup and I hold traction on 195/65/14 Yokohama AS430's.
Re: b16a rebuild: itr conversion?
bump
just thinking i might just do itr pistons and a built head with itr cams wut u guys think then maybe just chip the ecu and call it a day
Re: b16a rebuild
and if you do decide to build it all motor or boost it, dont just chip it. get it tuned on hondata and itll last forever and you wont be one of the kids on here with the thread name "chrome ecu built b16 issues" do it right the first time period whatever you do
Former Moderator
Re: b16a rebuild
Former Moderator
BTW:
I doubt the OP's friend who can "make a B16A 1.8L" knows about this, but there was actually a custom piston kit that allowed the use of the larger [b]STOCK 1834cc B18B LS crank and rods in the B16A block. The kit included custom Arias pistons that basically raised the wrist pin location and rings/lands way up in the piston.
Click HERE to read about the Tech 43 Racing kit from back in 2004
I did a simple Google search and the first link that popped up was this Eagle B16a 1.8L stroker kit
Now would I personally stroke a B16A to 1.8L?
Hell no.
The R/S ratio would not be nearly as reliable as the good old B18C 1.8L block with it's taller block and longer rods.
If I were the OP I'd look into a 1.8L block swap and raise CR with some pistons, get some good cams, and a GOOD port job if budget allows.
Otherwise boost it and make more whp for less money than an N/A build (but not be as cool lol.)
Hell no.
