b16a question
b16a question
i just recently aquired a b16a. i am sure it is an obdo motor as for the intake manifold says pgm-fi.. question. will my fuel rail and injectors from my b20 fit this b16? also will the stock intake manifold from a 99-2000 si fit it also or is the obdo a better intake?this was in a 91 crx which was converted and running obd1
Since their both B series, yes, they are all interchangable. SInce it says PGM on it, thats a good sign that its OBD0, ive never even seen anything but the older accord motors say that on their manifold. Since its OBD-0, that means that your dizzy is wired differently and needs to be re-wired to work with any other OBD harnesses.
Then it should swap right in no problem then.
Being that its an older B16, my first concern is the transmission, the older B16's used Cable shifters, whereas the later ones use Hydrolic ones (shift Linkage)
Ek Forever y0!
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Then it should swap right in no problem then.
Being that its an older B16, my first concern is the transmission, the older B16's used Cable shifters, whereas the later ones use Hydrolic ones (shift Linkage)</TD></TR></TABLE>
I was just thinking that, See if it's got cable-lines for the linkage hookup.
If it does the swap will be a PITA having to do a cable swap, easier to get a hydro tranny.
Re: (ek forever guy)
it has a hydro trans...he tried to put this setup n a del sol...it is a ls 5spd.
i have a b20 with a gsr 5spd (with ls 5th)in my hb now. i just don't want a bunch of troubles.
IHEARTMYHONDA91
05-17-2010 06:00 AM
