B16a into my EK HELP!
Re: B16a into my EK HELP!
The car should still run without the crankshaft fluctuation sensor(located at the crank). Assuming you're attempting with the P2P ecu. The P28 w/ Jumper harness will not look for this sensor.
Does your CEL come on and go off?
Does it have Injector Pulse?
Do you have all your grounds tight and clean, T-stat housing, trans to chassis etc..
I do believe I have injector pulse, but we've tested the plug wires for spark, and theres nothing. Ive re-checked all the grounds multiple times and re-surfaced them all as well.
My CEL comes on, and stays on while the ignition is on with the P72, but with the P2P it comes on and goes off.
reanimation
06-05-2012 08:09 PM
DualCamDan
09-18-2009 10:49 AM
SuicideSlide
05-17-2005 09:39 AM
