b16a head on b18c5 block. which timing belt? which spark plugs? (b16a or b18c5)
b16a head on b18c5 block. which timing and alternator belt? which spark plugs? (b16a or b18c5)
Are all b series timing belts and alternator belts the same? Do i use the spark plugs meant for the head or block? thanks guys
Re: b16a head on b18c5 block. which timing belt? which spark plugs? (sleepycivix)
Use all ITR parts (belt etc)
b16 belts are shorter then b18 belts.
Alternator belts are the same across all b-motors
Re: b16a head on b18c5 block. which timing belt? which spark plugs? (w00t!)
also.. i want to buy ARP head stud set... do i get the set for b16a or b18c5?? thanks
1 Post
b18c5. You basically have an ITR motor.
The heads are the exact same...except for the mild p&p and valvetrain.
Re: b16a head on b18c5 block. which timing belt? which spark plugs? (fowler)
anything like timing belts, head bolts, etc, you need for the b18c. deck height on those blocks is 7mm taller, so b16 stuff is too short.
fowler is correct in that the heads are of the same casting (save for the mild p&p). valvetrain, cams, IM, TB are different too.
tomx0071
06-06-2019 08:20 AM
sleepycivix
10-18-2002 06:13 AM
sleepycivix
10-17-2002 06:04 PM
