b16a gen II on 2000 civic ex throwing codes!
Ok I just got an 2000 civic ex with a obd1 b16a(jdm) gen II swap, the car runs fine and everything but it throws a couple of codes 1 and 23 which I believe is o2 primary sensor and knock sensor, I've researched a lil bit about the knock sensor, but where is the o2 primary sensor located? And since its a jdm b16a gen II swap, what o2 sensor is compatible with it? One from an ek civic si? Also the car has no cat, just a test pipe so I dnt kno if that has to do with anything. And how should I fix the knock sensor in this specific set up? Thanks guys
Re: b16a gen II on 2000 civic ex throwing codes!
primary 02 is right before the cat, you can use the one off your old motor if you still got it , if you are running an obd1 ecu test pipe won't throw any codes, if you are obd2 then it will cause a cel
gl
gl
DC5ftmfw
04-17-2007 08:39 PM
