b16a code 9 cyp?
Old 01-30-2011, 01:19 PM
jthrasher1's Avatar
Default b16a code 9 cyp?
i got a code 9 on my jdm b16a which is for the cyp sensor is my best bet to just replace the distributer or are there other thing i should try first?
Old 05-01-2012, 06:19 AM
ed98ex's Avatar
Default Re: b16a code 9 cyp?
Bump.. I got the sane thing on my b16a2 eg hatch. I'm running p06 converted to vtec. Car runs great,, idles at 500-600rpm I can take it to tedline ok with vtec engaging at 5800rpm. Cel is on for code 09-1 cyp sensor. Where can I start to find the problem?
Old 05-01-2012, 08:02 AM
Technical Hero
HondaPartsHero's Avatar
Distributor
Old 05-01-2012, 08:10 PM
ed98ex's Avatar
If I buy a new dizzy from autozone what car will I have to say its for?
Old 05-02-2012, 05:47 AM
Technical Hero
94-95 DEL SOL VTEC (make sure it's not the SOHC VTEC engine)
Or 92-95 Integra GSR
Old 05-04-2012, 09:30 AM
ed98ex's Avatar
Thanks I bought the car with the swap but I also noticed the current dizzy says td87-u? What car is that from? I'm confused on what dizzy to buy.
Old 05-21-2012, 01:53 PM
ed98ex's Avatar
Well I tried a new dizzy and code still came up. Also with the new dizzy the rpms and speedo won't work. So I put the old one back on and returned my new one. What else can I try, I have till next year too pass emissions.
Old 05-21-2012, 01:59 PM
Former User's Avatar
If you reset the ECU, does code 9 return?
Have you resistance and short tested the two CYP wires and sensor?
Old 05-21-2012, 02:36 PM
ed98ex's Avatar
Yes I tried resetting the ecu and the light comes back on. No I haven't tested the wires, how and what do i need to test those two wires?
Old 05-21-2012, 03:14 PM
Have you already read through this recent thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/00-civic-dx-has-codes-8-9-need-help-diy-distributor-replacement-3053972/
ZC DOHC CRX
05-20-2009 10:52 PM
gnar kill
02-20-2006 12:28 PM
sirex89
02-04-2006 09:35 AM
Quick Reply: b16a code 9 cyp?
