b16a in 2000 civic si
my friend has a 2000 civic si and has a b16a in it but vtec does not engage and car is running like **** hes running a stock harness with 2000 civic si ecu whats needed to make vtec engage and to get it running good
Re: b16a in 2000 civic si
yea the problem is that its a old jdm motor no crank sensor and stuff like that so no vtec i want to know what ecu and what harness to use to make vtec work
Seagull Management
If its a JDM OBD2 B16A it will also not have a vtec pressure switch and the USDM will look for it and vtec will not engage. Either use a USDM vtec solenoid, or connect the signal wire going to the non existant pressure switch and tap it into the wire going to the vtec solenoid.
no you can use a P28 ECU that is chipped to run a B16...BUt he will need to used OBD2 to OBD1 wiring harness to run the P28...
Seagull Management
Yes, I'm aware of that, but EX-T simply said a P28, implying a stock unchipped P28, which is certainly less than an optimal solution. In any case its not that hard to make a JDM B16A work with a USDM P2T ECU. You simply need to preform the CKF fix and tap the vtec pressure signal wire into the vtec solenoid signal wire.
