b16 wiring...
b16 wiring...
would it not be easyer to install a b16 into a eg hatch useing the 95 delsol wireing harnes? jdm b16a2 obd1 would not it be plug and play? or what would be the easy way to wire the motor into a 93 si hatch?
Re: b16 wiring... (93sihatchy)
should just reuse your stock egSI harness...just run the knock sensor if you are using the ecu from the b16 motor...easiest way there is man...gl
Re: b16 wiring... (ek4_b16a)
then i would have to wire in the knock senior cant i just pull a 95 b16 delsol 's and plug and play? but other then that ty.
