b16 water inlet goes no where?
I have a b16a jdm crx head on a b16a2 usdm si block and I've recently hooked up all the hoses except one, I cant find where this goes, do I just block it off?
Re: b16 water inlet goes no where?
This diagram may help.
I also do not have an oil cooler on my b16, should I have one? I dont have any coolant openings for a cooler
thank you for that, ill go and check if i have the fitting on the thermostat housing, could have swore i didnt see one, maybe i missed it
yeah, just went and checked my thermostat housing where it would connect on the other side according to the diagram and its not there. i only have 2 big fittings on my thermostat housing for the heater core and the one bypass that goes to the intake manifold.
just as i thought there is no where for it to go. i double checked everything, everything is hooked up correctly, im just left with this last one that goes no where!
I don't have my EM1 anymore so I can't go look at it and confirm routing of hoses and without seeing your set up in person or more photos of how stuff is ran currently I can only give so much help. I had the nipple you are talking about capped. I just picked up a coolant cap that was the right size and threw an extra hose spring clamp on it, I did the same thing with the nipple on the water pipe. Ran like that for years with no issues.
Fish Twig
I"m guessing that the the jdm crx b16a had an FITV? I see 4 hoses, in the image I provided, that lead to the throttlebody.
yes I believe the head was from an 89 crx jdm, but I have my heater hoses right, i have coolant going to the throttle body and iacv I just have no clue where it would go, I guess I'll end up capping it I can post more pictures, also what is a FITV?
Water pipe on back of block to iacv, iacv to fitv (or just the nipple under the throttle body),fitv (or nipple) to the port you originially asked about. If you still had the oem breather pipe, it would go between the tb nipple (or fitv) and the nipple you asking about. Hope this makes sense.
Your IACV and the T/B both have two 5/16" coolant line fittings (or should have anyway)... basically an IN and an OUT for each. Ignoring them for a moment, count up the number of fittings remaining on the engine that match the size of the fitting you have pictured on the upper radiator water neck. These fittings can be found on the following locations: Water pipe, thermostat housing, intake manifold (especially aftermarket ones like a Skunk2 or Blox), and the previously mentioned upper radiator water neck. If you have an EVEN number, you will not need to plug or remove the fitting that you have pictured. If however, you have an ODD number of fittings, the odd fitting must either be "T"eed into the coolant circuit or plugged/removed.
Now go and count. Also, it would be helpful if you can describe how you currently have the coolant circuit connected currently... and photos will help.
thank you for your time your a huge help, I'll grab pictures tomorrow morning
