b16 timing belt help
How do you do the timing belt on a jdm b16a? i need to know what to line the crank pully notch to? i can get the cam gears but not the pully. so if anyone can give me detailed instructions on how to do the timing that would be great. I also need help on how to tighten the timing belt itself.
Re: b16 timing belt help (jdmcivic1999)
just get a manual its the same as on a usdm b16 its not to bad just take your time and make sure you have everything lined up correctly
peace
eric
peace
eric
1 Post
on the block or oil pump housing, there is a line. line it up with the line that is on the oil pump drive pulley. the cam gears have little lines on them too, line those 4 lines up to each other. they should also have an arrow pointing UP. once you are there, put on your belt.
XkjeldorX
22
09-28-2007 04:11 AM
