b16 swapped eg no start
My 95 civic coupe with a b16a with type R cams msd modded cap and rotor and the car is on Ectune. The past few days I have been driving fine. Then the other day the battery light come's on and the car dies at the stop light. So new battery and plugs and all the car does it crank.
p.s just also found oil leaking for the head gasket down on the front of the block.
Re: b16 swapped eg no start....
The is a CEL when you first try to start the car, you can here the full pump, There are no white rings are the plug wires. My spark plugs where black as hell thought....like I couldn't even clean them off they where that bad.
Does the CEL turn on and then off after 2 seconds when the key is turned to ON(II)?
You need to check for spark. Click the Spark link in my signature.
Yea....I'm reading your post right know as we speak.
I have a hard time thanking this motor is blown...(knock on wood)
Re: b16 swapped eg no start...(solved)
OK!!! not solved....damn it man...so I did the spark plug test with spark plug tester and I'm getting spark here and there. So what should I do...
A) replace the blaster coil
B) replace the whole dizzy
LOL...thanks I need one....cause I have dyno time for next saturday....
Buying a new blaster coil today...wish me luck
slownlow619
08-29-2013 01:07 AM
