b16 swap....what should i do now???
i have a 92 civic hb, i just done a b16a swap, the engine is stock, if any body knows whats best for a b16 like timing, chipping, air, fuel anything without braking down the motor, please give any advice...thanks!
mugen oil cap = +10hp
Are posts like the above really necessary? https://honda-tech.com/forums/images...es/emsmile.gif
Anyway, do you have the regular i/h/e done already? That would be your first move, then it depends on whether youwant to go all motor or forced induction. Forced- Start getting internals and buying ecu parts so you can tune your own car instead of paying somebody 100+ an hour to do it Naturally Aspired- Decide on things such as individual throttle bodies and internals.. |
well i was told today that it woulden't do me any good to put i/h/e on because they said it won't help me any because my ecu isen't chipped...thats the first i heard of that...that is the only reason i put this post up.
IMO on top of I/H/E I would start getting the internals you need for boost, that by far seems to be the best way to go with civics...and no I'm not dissing the NA setups
Well whoever told you the info about i/h/e is full of it. It depends on your goals.
If you are wanting a super reliable daily commuter then I would say n/a or a good turbo setup, something not too ratical. The more power you go for, the less reliable, unless you have an amazingly good tune. Decide what you would like to do. I am still on the edge of deciding as well. |
Re: b16 swap....what should i do now??? (importkidd)
chipped p28, LSD, clutch, cams, solid mounts, short shifter, I/H/E.... that's a good start https://honda-tech.com/forums/images/smilies/emthup.gif then you could look into a throttle body, bigger injectors ect.. It's always good to take your car and get it tuned aswell....
boost it
thanks guys!!!!!!!!
Re: (importkidd)
I/H/E cams, chipped ecu, good suspension set up
iono why pple want a good suspension set up, it's not useful unless u wanna drop the car (make it a show car or just make it look hot) or you take it to the track, I mean on a daily commute you don't need a 3k brand name suspension setup
which is better chipped p30 or a chipped p28???
it wont really matter when you start tuning it. we tuned a d16 with a greddy turbo today and started with a p30 map.
