b16 swap help! runs like poo
I just did a b16a swap in my 99si. the motor was in a boosted car and i have all his turbo stuff.when i start it idles fine but as soon as i give it gas it just cuts out and won't go past 2500 rpms. all my wires seem to be ran right and my tps and map are all working fine. not really sure whats going on. im prolly forgetting somthing so if i am just ask. any help would be great.
Re: b16 swap help! runs like poo
check your distributer you might think its right but it might be wrong on the wiring trust me............also check your injectors make sure theyre obd2
I would guess ckp is not reading right. which is in the dizzy. I had same problem with my ek swap. Although mine was a broken wire somewhere in the loom.
Jus an idea tho
Jus an idea tho
thanks
TK209, your running a b16a2 with a gsr ecu. You do realize that the gsr ecu was meant for a gsr motor and not a civic 99-00 (b16a2) motor... Get a chipped P28 for a B16 and you should be good. Your car is probably also in limp mode.
As for limp mode, it is the mode the ECU goes into when it reads a catastrophic failure, or when the ECU is bad itself. Basically it reverts to a rich base map and limits revs to around 3000 (depends on what your tach reads).
I'm sure you can run it. But it isn't ideal as the fuel will be off as well as the timing and everything else for it. GSR's also have secondaries. If both cars have CELs and are running like crap and doing the same thing... chances are its in LIMP mode. Bottomline, run the correct ecu for the correct motor and save yourself the headache.
The code was intake temp. Im running a chiped p28 on crome. put my buddys p28 tunned on hondata s200 and does same thing. both cars are built almost the same.
Ignitecivic
11-23-2004 10:07 PM
hYpE-R-29
10-30-2003 08:43 AM
