b16 swap help!
b16 swap help!
im puttin a b16a2 into my 93 ex coupe! used to have d16z6 just lookin for some Q/a's! so any help would be great full guys!
1- what injectors should i use? is there a way to make b16s work with my z6 harness? if i went after market? what size should i run on stock int/ with bolt ons?
2-can i use the stock b16 shift linkage?
3-can i use my throttle cable?
4-what block motor mount do i need for driver side?
5-can i cut and splice alt plug?
6- anything else i need? or need to know? should be gettin my mounts in like 2 days so just tryin to get ready! thanks guy for the info
Re: b16 swap help!
i need help too guide would be good but i got a complete jdm b16a2 was swapped in a crx 4got wat year was wondering if it will be a quick plug and play if i swap it in a 91 ls integra?
Re: b16 swap help!
2. yes, you can use any 94-01 integra linkage or the 99-00 si linkage.
3. use a 94-01 integra ls/gs/rs throttle cable, your D series will be too short
4. you should be able to use your stock driver's side mount. If it doesn't line up tho, take a look at this article to see what mount you will need http://www.hamotorsports.com/2boltvs3bolt.html
5. yes, you can cut the four wires to the alternator and splice the plug in place. If i remember correctly though, only two of the wires match colors. You may need to dig up a wiring diagram for the others.
6. Make sure you get the rear L bracket like this one as the 99-00 B16a2 bracket wont work.
Best of luck!!
CarRamRodEG
12-29-2007 10:21 AM
