B16 swap help
B16 swap help
I have a b16a i want to put in my EH civic dx, but its obd0, i know its a harder swap then it should be but thats all i got, how can i make the wiring work? and what mounts do i need for the swap
Re: B16 swap help
Everything else will bolt up fine.... Just as everyone else stated, get a Dizzy, Injectors, and Alternator... Make sure you have a Hydro Tranny or you will have to buy a hydro tranny for it or buy a hydro to cable conversion kit.
Re: B16 swap help
cable tranny yes but im converting the car itself to cable aswell and what computer do i use? and what about the wiring itself
Re: B16 swap help
You can get your ECU chiped to run it. I have a B18 swap in mine, and I am running my stock ECU still and it's not chipped. That's because all my sensors are the same as my stock engine.
Re: B16 swap help
the pr3 is for an obd0, you need an obd1 ecu.. You could do a chipped p06, but it would probably be better to just get a chipped p28.
Re: B16 swap help
well what about just converting the ecu wires to the obd0 clips seeing how the engine is obd0? would that work aswell?
Re: B16 swap help
it would be way too much hassle then you would have to worry about the wiring and all.. you would have to change a lot more than just the ecu wires because everything connects together...
Re: B16 swap help
allright well the engine is in... but it leans forward and is a little **** eyed... does the drivers side mount mount, as in whats between the engine n the engine mount (that mounts to the mount to the frame... god that was too much work to explane..) does the drivers side mount mount need to changed? i beleive that might be the problem seeing as how the mount is only held in by one bolt... and as for the harness... anyone have the colour to colour codes handy? for obd1-obd0... i didnt listen to the thread, i thought i had it under control, cept every wiring chart i found on the internet had different wire to wire patterns...
bobbyg crxh22
12
04-21-2006 09:14 AM
lastlude2k1se
10-13-2004 09:17 AM
hitvtecgetloud09
09-21-2004 10:11 PM
