b16 swap in eg **very rough idel** mising??
I recently swaped b16a2 into my eg.
Using a p28 with a skunk2 chip and z6 harness. The car idels very rough and once you rev it up on the down rev the car will almost stall. Ideling it will somtimes drop to around 100-220 rpms and bounce back to 750 and back down to 200.
New cap, rotor, plugs adn wires. Timing set to stock. Try using the stock p28 i have and still have this issue. i have tryed using 2 different IACVs too and still haev same problem. Any help would be greatly apperiated.
Re: b16 swap in eg **very rough idel** mising?? (Average Al)
are all the vacume lines hooked up?
my car ran shitty when i forgot to hook up the brake booster vacume line
update new PCV valve IM was cleaned out and new gasket used when put back on.
could valve clearnace begining out casue this??
I also removed charcoal canister if that makes a diff
Re: (Average Al)
Couple suggestions? There's 2 lines of importance running to the charcol canister in this case. 1 from the evap purge solenoid. I'm going to assume this is a JDM B16, so that's not a problem. If it isn't a JDM B16, you have a vacuum leak. The other "phat" line connects to the top of the intake manifold. You could try plugging that. I'm not sure which side it comes into the intake butterfly. If it's on the inside, you'd basically have a mild vacuum leak
(EDIT: It appears the evap recycle line comes in in front of the butterfly valve. so it's somewhat irrelivent)
Either that, or you didn't clean the old gasket off well enough or something, and you've got a vacuum leak at the joint between the IM and head.
As a side note if you take the charcoal canister out, at least route the gas evap line somewhere else. Venting gas fumes into your engine bay isn't your friend.
not jdm
its a usdm a2 motor
there was a big barb on top of the motor that i was not sure where it goes and it was on teh z6 i took out.
I just block it off with a rubber piece
its a usdm a2 motor
Re: (Average Al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al »</TD></TR><TR><TD CLASS="quote">not jdm
its a usdm a2 motor
I just block it off with a rubber piece</TD></TR></TABLE>
That's the port that goes to the evap purge solenoid. So that's fine as long as it's sealed.
Hmm..
Did you possibly not hook the PCV line back up? It runs from the engine-side of the IM, through the middile of it, and down to another black canister on the back of the engine. Or possibly it's leaking?
its a usdm a2 motor
Hmm..
Re: (project_mercy)
I see you replaced the PCV up above. I'd double check that. Assuming it's ok, start the engine, and spray some carb cleaner at the joint of the IM to the head. If the idle goes up, you've got a leak. Make sure you hit both sides.
TheRobotSpy
10-11-2009 08:02 PM
icemanAKA92eg6
05-22-2008 11:05 AM
Yak BallZ
21
11-21-2006 11:08 PM
