b16 sputtring at low throttle decel
ok my b16 is running god but when im cruising and i get off the throttle a little and the rpm begin to drop i get a sputter. it does no happen at any other time only when i slightly get off the gas. just trying to figer out why i already cleaned the cap and rotor the plugs are new and are properly gapped
any help would be appreciated
Re: b16 sputtring at low throttle decel (bleedblue94)
What do you mean by sputter? From the exhaust? Mine would do that but I had really free flowing exhaust. More info would be good.
Re: b16 sputtring at low throttle decel (Octoman)
well i can hear it through the exaust bc its loud you know you have a nice hum then put,put, put then its ok again only does it on decel at part throttle its only done it since i swapped the p28 in
Well for me, i had a major sputtering problem. Sometimes the engine would just die on me. My problem was a loose ground right below the throttle body area, on the tranny. Since you said you just changed your ECU, try a different one and see if the sputtering stops, if not you know its not your ECU. Their is no definate answer, just gotta go over a process of eliminating the possible problems. Check if your spark plug wires have any tears. Do a search also, lots of past topics about this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">well i can hear it through the exaust bc its loud you know you have a nice hum then put,put, put then its ok again only does it on decel at part throttle its only done it since i swapped the p28 in </TD></TR></TABLE>
So, you're saying that when you let off the gas, the exaust goes pop, pop, pop or something like that? If there are no other problems (stalling, RPMs dropping) and you have a non-stock exhaust, this is perfectly normal.
itsJDMyo
05-30-2004 04:05 AM
