b16 question?
Old 12-30-2004, 10:54 AM
oscar_lopez03's Avatar
Default b16 question?
i was looking at hmotorsonline and i saw that they have several b16 for sale. what would be the difference between B16A 88-91 (SiR I), the B16A 92-93 Integra (XSi) and the B16A 92-95 (SiR-II)
mind u the motor is going to be put into a 94 civic coupe. just wanted to know what was the difference and what would be the best one to get.
Old 12-30-2004, 10:57 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: b16 question? (oscar_lopez03)
i am not sure on the differences between the crx sir and the x-si. but if you are swapping into a 94, to save a whole lot of heartache, get the sirII swap. it is plug and play. plus the fact that the sirI and x-si are cable trannies. the sirII is a hydro trans and will swap much easier.
VinhTEC's Avatar
i kno that the number 2 b16 has a hydro tranny and the 88-91 is a cable tranny and u probably want the b16-II cuse ur car is hydro mostlikely and the xsi i dont remmber i heard of that but forgot ohhh well i like single cams dont laf!!!!!
Old 12-30-2004, 11:40 AM
Default Re: b16 question? (VinhTEC)
well there is a big price difference in each. the tranny would be the differnce?? how about i piece together my own b16, would that be cheaper or more money??
Old 12-30-2004, 11:50 AM
PHOBIA's Avatar
no it woud not be cheaper.the newer b16s models with out a cable tranny have 10 more hp.the xsi came from a interga xsi from japan the also have 170 hp instead of the b16's that came from the civis wich had 160 hp.
Old 12-31-2004, 07:36 PM
also what would be the best parts to get if i decide to go all motor.
what would be a set of good cams, cam gears, pistons, rods etc etc etc.
Old 12-31-2004, 07:51 PM
PHOBIA's Avatar
all motor costs way to much money for less performance than would could be had with forced induction.
Old 12-31-2004, 10:12 PM
xZeler8's Avatar
Default Re: (PHOBIA)
get the SiRII and make sure your wiring harness is prepped for a det. sensor
Old 01-01-2005, 10:21 PM
yea but all motor would be more expensive but in the end it would be efficent than a turbo. a turbo is to much money to maintain.
Old 01-01-2005, 10:25 PM
Mario.'s Avatar
Default Re: (oscar_lopez03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscar_lopez03 &raquo;</TD></TR><TR><TD CLASS="quote">yea but all motor would be more expensive but in the end it would be efficent than a turbo. a turbo is to much money to maintain.</TD></TR></TABLE>
An N/A motor setup will give you your hardaches as well. Building a fast car is not cheap no matter which way you tackle it.
Old 01-01-2005, 10:26 PM
eL
eL's Avatar
turbo is WAY less money though.
Old 01-01-2005, 10:30 PM
Luserkid's Avatar
Default Re: (Mario.)
SIRI = OBD0 motor, and tranny is cable.
XS-I = OBD1 motor and tranny is cable (Good for 88-91 cars that want to convert to OBD1 but not to hydro tranny)
SIR II = OBD1 motor and Hydro Tranny, what you want for your civic.
Old 01-02-2005, 09:46 AM
Default Re: (Luserkid)
so the the best thing to do is get the sir II, which i am going to get.
can anyone help me to tell me what are some good parts to get if i decide to go all motor
Old 01-02-2005, 09:57 AM
Luserkid's Avatar
What like cams, pistons, rods, etc? You want us to tell you what to use to build your motor? Why not research and build your own.
DEPintheCurve
40
06-05-2009 10:59 AM
cmiller219
11
08-19-2007 08:12 PM
91ZCcivicSi
03-05-2005 03:36 PM
dohcMONSTER
12-05-2004 02:34 PM
hitvtecgetloud09
09-21-2004 10:11 PM
Quick Reply: b16 question?
