b16 out of Del sol into 97 civic
Are there any motor mount differences from the Del sol B16 into a 1997 Civic EX?
I know the b series mounts are different and what not, but will the new mounts bolt in to the civic with no problems or do I need 99-00 civic SI mounts?
Seagull Management
Re: b16 out of Del sol into 97 civic (Christian_D)
Rear T/L bracket '99 - '00 SiR (nothing else originally from north america works) top transmission bracket '96 - '00 civic 5 speed, any model. Timing belt mount (I believe you can use the civic unit here, you may need to use both the mount and bracket though. Both torque mounts you can make using the brackets from the del sol and the mounts from the civic, the del sol mounts may actually be the same as the civic, you'll have to check and see for yourself.
xChrizcrozzx
08-21-2014 05:15 AM
turbowagon94
06-14-2010 02:27 PM
xshortx
18
08-29-2009 11:04 AM
hotimportcrx
11-27-2005 09:32 PM
