b16 map sensor rhd integra
hey i got a 98 integra (rhd). i put a ls/vtec into it, the head is a b16. i'm tryin to wire up a rhd b16 engine harness. problem is the map sensor, doesn't seem to be any plugs that fit the map sensor. i am using the map sensor from a b18b, my questions are does anyone know the colors of the wires on the b16 (obd1) map sensor, and how many wires it has running to it, also where is the map sensor located on a b16 obd1, i heard the clip could be on the headlight harness but i don't see it there either. thanks
Re: b16 map sensor rhd integra
You could just get the clip from any of the vehicles listed here (autozone website): http://shop.oreillyauto.com/ProductG...tnumber=FE1680
Part Number: FE1680
This product fits the following vehicles.
Acura
1997 - 1999 CL
1994 - 2001 Integra
Honda
1994 - 1997 Accord
1997 - 2001 CR-V
1992 - 1997 Civic
1995 - 1997 Odyssey
1993 - 1997 Civic Del Sol
1996 - 1998 Prelude
Isuzu back to top
1996 - 1997 Oasis
The wiring color should be the same but here is a YouTube video that basically explains the MAP operation. So all you will need to do is just get a volt meter and test the lines for ground, voltage (5v) and signal (which will vary, hook up the volt meter and rev the engine if the volts fluctuates then you have found your "Signal" line).
Turn the volume down. Its really loud!
http://www.youtube.com/watch?v=ijK2LsN8ipw
I hope this helps...
Part Number: FE1680
Acura
1997 - 1999 CL
1994 - 2001 Integra
Honda
1994 - 1997 Accord
1997 - 2001 CR-V
1992 - 1997 Civic
1995 - 1997 Odyssey
1996 - 1998 Prelude
Isuzu back to top
1996 - 1997 Oasis
Seagull Management
Cian Mcloughlin
05-20-2013 10:11 AM
EGsixer
01-31-2004 06:22 PM
