b16 or LS?
b16 or LS?
i have a delsol jdm b20b swap p8r head with a b16 tranny. is it worth the short gears to keep the b16 trans over the ls? im taking all opinions
Re: b16 or LS? (MrMug3n)
I wouldnt downgrade to a LS trans. Short gear ratio is alot better. If you wanna get the best, get a ITR trans, as it has pretty good balance of gear ratio and has LSD
Re: b16 or LS? (Mr.Highlife)
GSR or B16 if you're not looking to spend a whole lot. But I definitely wouldn't go down a step by getting an LS tranny.
yea you can change out the gears....but the questions that should be asked is
why do you want to change the trans? What's your reason for this?
Better gas mileage? or cause you want something to do? or u wanna be faster?
Re: (Malakai)
i wana be faster who dosent but i also want to be able to take my car out of town with out hitting redline doing 90 lol just searching my options
thanks for the input fellas
Re: (MrMug3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMug3n »</TD></TR><TR><TD CLASS="quote">i wana be faster who dosent but i also want to be able to take my car out of town with out hitting redline doing 90 lol just searching my options
thanks for the input fellas </TD></TR></TABLE>
are you going N/A or turbo? IMO if your going turbo get the LS coz it has longer gears than the b16 trans. Plss correct if im wrong about this.
i understand what this guy is saying i as well have a b16 tranny and they suck if you just are cruising around the highway its like 3200 rpms in 5th doing 55 it sucks.
Re: b16 or LS? (Kurly)
gsr and ls trans have the same first and second gear but with differend final drives. The gsr of course is geared lower.
The b16 trans has the shortest gears out of the three with the same final drive of the gsr. Short gears = faster acceleration.
All tranny's in 5th gear @ 8500rpm with a 23.4" tire
B16 ~158.6mph
GSR~ 170.9mph
LS ~ 194.3mph
All tranny's in 5th gear cruising at 70mph with a 23.4" tire
B16 ~ 3752rpm
GSR~ 3482rpm
LS ~ 3063rpm
Just to give you a idea of your cruising speed and your top speed. If the b16 trans dont let you get enough speed in 5th then i think you need somethin other than a civic to go fast
B16 ~158.6mph
GSR~ 170.9mph
LS ~ 194.3mph
B16 ~ 3752rpm
GSR~ 3482rpm
LS ~ 3063rpm
DA is best
13
01-29-2007 11:09 AM
