B16 with a Drive Plate on the motor instead of a flywheel
New User
B16 with a Drive Plate on the motor instead of a flywheel. Is this only for the automatic transmission motors or will i have a problem doing my motor swap as a 5-speed?
Re: B16 with a Drive Plate on the motor instead of a flywheel (5 0 DIPPA)
Remove the plate, and there may be a little spacer/ring in the end if the crank that is pressed in. Use some vicegrips and pry it out (lock grips on the lip of the spacer, and pry the nose of the grip against the crank, alternating sides until it's out). Flywheel should bolt right up to the crank(i.e. the plate and flywheels use the same bolt patters) Later!
SIRIUS VTEC
16
08-10-2010 07:57 PM
FAQ: removing flywheel using nothing but a ratchet, 17mm 12pt socket and 9/16th box wrench? no preob
BlueShadow
14
07-31-2004 04:45 AM
TeamCracka
03-11-2004 03:43 PM
