b16 -> b18c5 swap?
b16 -> b18c5 swap?
Whats up guys,
I have a 98 civic coupe with a B16a in it and just bought a JDM ITR motor. I'm planning on building the motor first before I put it in but I'm just wondering if it will drop right in with no mods since I already have a b16 in right know. Am I right?
Thanks (in advance)
Thanks (in advance)
Re: b16 -> b18c5 swap? (deepnite)
Dood you should''nt have a problem instaling if you do go to this guy in Westminster's shop called Prospeed Performance reasonable prices and the best work installed myfriends ls-vtec no problems.
website is http://www.prospeed-performance.com
good luck bro
good luck bro
Re: b16 -> b18c5 swap? (50percentRice)
you should have a problem , but are you running an obd 2 on the b16 , cause i beleive the b18c runs different vtec silinoid and also i beleive the oil pump but im not that sure on the oil pump doe .
Fired Honda
07-26-2003 08:17 PM
