B swap in a 92-95? im sure it has been covered
just wanted to know what was involved in doing this? do i need to change trannys? axels? ecu? harness? shifting linkage....
thanks for ur time/./
Re: B swap in a 92-95? im sure it has been covered (commotion)
sure has. Check the search function. Basically, get the B series tranny and mounts from 94-01 integra, along with linkage and axles. Good luck, this is fairly simple swap. Try the search. Use these. B series swap. Or LS in EG or B series civic. Good luck.
b18c5-eh2 put together a nice archive just for this type of thing its at the top of the page...
here is the link anyways
https://honda-tech.com/zerothread?id=642479
there is a ton of info in here... it should help you out alot
jstanthr95civic
05-09-2005 11:55 PM
