B-series transmission question
Old 11-09-2005, 05:16 PM
L8apex's Avatar
Default B-series transmission question
Replacing the bearings in my B16A/S4C transmission and the OEM replacement countershaft bearing on the transmission case is missing an oil hole. This is the needle-type bearing.
The original bearing has an oil hole and the factory manual says to install the bearing with the oil hole facing up. This is the correct bearing since it fits into the housing and onto the countershaft, but it's just missing the oil hole. Any ideas? Thanks in advance.
Old 11-10-2005, 08:44 AM
L8apex's Avatar
Default Re: B-series transmission question (L8apex)
Bueller? Anyone?
Old 11-10-2005, 08:52 AM
JDM-97CX's Avatar
If it doesn't have the hole it is not the correct bearing. I can fit in an oven, does that mean that I am the thanksgiving turkey?
Old 11-10-2005, 11:57 AM
L8apex's Avatar
Default Re: B-series transmission question (JDM-97CX)
Still not sure....Took the bearing to the dealer to check it with their database and the part numbers are correct.
ps. I ordered the bearings by part number, not by diagram, so I just had to double check it.
mmmm.....turkey
Old 11-10-2005, 12:43 PM
Circuit Star-29's Avatar
Get de bearing wit de Hole...
Old 11-10-2005, 01:46 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L8apex &raquo;</TD></TR><TR><TD CLASS="quote">Still not sure....Took the bearing to the dealer to check it with their database and the part numbers are correct.
mmmm.....turkey</TD></TR></TABLE>
Well if the dealer says it is the correct part number then my advice would be to ask their heavy tech if it looks correct to him, if he says yes then use it.
Old 11-10-2005, 06:29 PM
acy76's Avatar
For what it's worth, when I was swapping GSR internals into my YS1, I decided to get the GSR countershaft bearing as it had a different PN than the YS1 bearing did. The only difference I noticed was the absence of the oil hole - maybe it's a new design? Anyway, a few thousand miles later and no problems. I imagine you'll be fine if you use it.
Old 11-10-2005, 07:52 PM
L8apex's Avatar
Default Re: B-series transmission question (acy76)
Excellent. Thank you.
Hooch'n
09-01-2006 11:05 AM
DjDrift
10-02-2004 08:05 AM
turbociv
15
03-11-2004 01:16 PM
dustin
10-23-2002 12:06 PM
Quick Reply: B-series transmission question
