B series mounts for D series motor
Hey guys i have a quick question. i have a rear mount and riverside mount for my 96-00 civic for a b series motor (innovative Billet 75a durameter). will these two mounts fit for a d series motor as well? my friend is lookin to swap a fresh y8 into his ex and was wondering if these mounts would work. i know the driver side one does, but is the rear one the same?
Re: B series mounts for D series motor
Are you talking about the actual rear L mount?? if you are then no it won't work, if you are asking about the mount that the L mount bolts to then it is very possible.. just have to look at the stock mount and see if its the same..
Ok, you are asking a ? because your friend is putting it into his car, I figured that you could look at it while his motor is out. I'm thinking it'll work, but you know it helps to not be an ***.
lol im not an *** man, its a simple question, the motor is still in his car. stock d rear mount is not accessible at this current moment, once again if it was, i would not be asking this question, and there wud be no thread to be made, all you have to say is that you do not know, thank you.
i know the driversides are the same, but the trans are def different, but idk bout the rear
and as I said i'm pretty sure they're the same.. but I was also just saying to make sure you could look at them.. I thought maybe the motor was already out since you said your friend was putting one in it..
i was just going to add real quick that the mount should fit on the car considering that when ppl do a b series swap on the ek's and eg's as well they usually just change the back L mount, when they're doing the back mount.. so it should work fine with the d series..
yeah, don't blame you on wanting the answer... it was just a thought for ya .. i'll try to do a little searching too..
their customer service is terrible, they sent me the wrong front upper control arms, i sent the one wrong that they sent me, and they claim they never got it. so now im stuck with one control arm for 174.99. Nice guys. www.xenocron.com. closer than cali and cool guy. he carries all kinds of mounts. **** robear
rear mount...yes. drivers side mount...if the motor has a 2 bolt post and the mount is for a 2 bolt or 3 bolt and 3 bolt, it will work.
cxVtecC1
06-03-2005 06:48 PM
