B][/B] Need help asap
recently my car been ridin like ****. i crank it up in the morning it runs for 2 seconds then it cuts off. try it again runs for a couple of mins then cuts off. after the car gets warmed up it will stay on. i check the codes and it threw(10 IAT - intake air temperature sensor )(41 Primary oxygen sensor heater) so i changed the temp sensor replaced the spark plugg wires, plugs, distr. cap and i still have the problem. Also when i drives my car studders like at 3500 rpm like how a spark plugg arks but then it rides fine. i need some help please help
Re: B][/B] Need help asap (RidinOnE)
take the sensor out and clean it off...they go bad a lot...be careful or you will strip the screws out...i dont know how much they are...but try the parts store before you go to honda
i have a 99 ex motor in my 92 civic and i only have 1 sensor which is after the converter so just clean that one sensor. also i just tried to crank the car tonight around 1 am in georgia and it wont crank at all is that the sensor too
sleeper93hatch
02-11-2009 05:23 PM
