Axles
Axles
well i got everything of until i hit the **** where i had to split the hub from the lower control arm. the problem is that i couldn't get the knuckle balljoint to split them two... is there any other way i can do it??.... i pund on the lower control arm like crazy... not a thing... any other suggestions... it'll be helpful thanks..
Re: Axles (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">cook that sucker red hot with a torch, then hit it with the hammer</TD></TR></TABLE> hell yeah, or try using a ratchet and pipe to pry them apart
Unceasing Measure
Re: Axles (SOHCD16y8)
Or you can take the suspension apart at any of the junctions, including but not limited to the LCA where it meets the subframe, the UCA where it meets the subframe and the strut top mounting nuts.
It's just like LEGO only bigger. You'll figure it out.
I am a (Trial User) Army
Re: Axles (Archidictus)
Archidictus has the best idea here. I thought of this too when I had to take mine out. Unbolt the lca from the frame and then the 3 bolts that hold the big bushing bracket to the frame. If you have air tools, this will take 2 mintues.
Or
If you are really set on popping out those lower ball joints, check this thread out and it'll change your life: https://honda-tech.com/zerothread?id=887859
Or
Re: Axles (hmongyaj7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Archidictus has the best idea here. I thought of this too when I had to take mine out. Unbolt the lca from the frame and then the 3 bolts that hold the big bushing bracket to the frame. If you have air tools, this will take 2 mintues.
Or
If you are really set on popping out those lower ball joints, check this thread out and it'll change your life: https://honda-tech.com/zerothread?id=887859</TD></TR></TABLE>
that post=gold
Or
that post=gold
Black 2K
07-06-2003 06:12 AM
guttedhatch
05-28-2003 08:09 AM
